Porsche 997 GT3 R Hybrid
- SebM
Message par SebM » 11 févr. 2010 11:19
Porsche Press a écrit : 911 GT3 R Hybrid Celebrates World Debut in Geneva
Exactly 110 years after Ferdinand Porsche developed the world’s first car with hybrid drive, the Lohner Porsche Semper Vivus, Dr. Ing. h.c. F. Porsche AG, Stuttgart, is once again taking up this visionary drive concept in production-based GT racing: During the Geneva Motor Show, a Porsche 911 GT3 R with innovative hybrid drive is making its debut, opening up a new chapter in the history of Porsche with more than 20,000 wins in 45 years scored by the extremely successful Porsche 911 in racing trim.
The innovative hybrid technology featured in the car has been developed especially for racing, standing out significantly in its configuration and components from conventional hybrid systems. In this case, electrical front axle drive with two electric motors developing 60 kW each supplements the 480-bhp four-litre flat-six at the rear of the 911 GT3 R Hybrid. A further significant point is that instead of the usual batteries in a hybrid road car, an electrical flywheel power generator fitted in the interior next to the driver delivers energy to the electric motors.
The flywheel generator itself is an electric motor with its rotor spinning at speeds of up to 40,000 rpm, storing energy mechanically as rotation energy. The flywheel generator is charged whenever the driver applies the brakes, with the two electric motors reversing their function on the front axle and acting themselves as generators. Then, whenever necessary, that is when accelerating out of a bend or when overtaking, the driver is able to call up extra energy from the charged flywheel generator, the flywheel being slowed down electromagnetically in the generator mode and thus supplying up to 120 kW to the two electric motors at the front from its kinetic energy. This additional power is available to the driver after each charge process for approximately 6 - 8 seconds.
Energy formerly converted – and thus wasted – into heat upon every application of the brakes, is now highly efficiently converted into additional drive power.
Depending on racing conditions, hybrid drive is used in this case not only for extra power, but also to save fuel. This again increases the efficiency and, accordingly, the performance of the 911 GT3 R Hybrid, for example by reducing the weight of the tank or making pitstops less frequent.
After its debut in Geneva the 911 GT3 R Hybrid will be tested in long-distance races on the Nürburgring. The highlight of this test programme will be the 24 Hours on the Nordschleife of Nürburgring on May 15th and 16th. The focus is not on the 911 GT3 R Hybrid winning the race, but rather serving as a spearhead in technology and a “racing laboratory” providing know-how on the subsequent use of hybrid technology in road-going sports cars.
The 911 GT3 R Hybrid is a perfect example of the Porsche Intelligent Performance philosophy, a principle to be found in every Porsche: More power on less fuel, more efficiency and lower CO2 emissions – on the track and on the road.
- La grenouille
Message par La grenouille » 12 févr. 2010 09:10
Cela devait être d'abord sur le Cayenne.jeromede a écrit :nice!, bientôt sur le cayenne?
jerome
- jeromede
Message par jeromede » 12 févr. 2010 09:25
Pourquoi devait?La grenouille a écrit :Cela devait être d'abord sur le Cayenne.jeromede a écrit :nice!, bientôt sur le cayenne?
jerome
Ils lui ont préféré le mazout, mais l'idée est définitivement abandonnée?
A+
jerome
Enfin, avec mes règles simplifiées parce que les règles originales, elles sont velues...
- La grenouille
Message par La grenouille » 12 févr. 2010 11:57
C'est comme ça qu'ils sont devenus célèbre alors pourquoi pas.
Le politiquement correct suivra de toute façon.
Message par Corsugone » 12 févr. 2010 13:37
- jeromede
Re: Porsche 997 GT3 R Hybrid
Message par jeromede » 12 févr. 2010 13:39
Une petite chose que je ne comprends pas cette "GT3R" est une intégrale?SebM a écrit :Porsche présentera à Genève une version hybride de sa 911 GT3 R...![]()
les roues avant disposent chacune d'un moteur?
merci,
jerome
Message par Corsugone » 12 févr. 2010 15:15
Ouijeromede a écrit :Une petite chose que je ne comprends pas cette "GT3R" est une intégrale? les roues avant disposent chacune d'un moteur?
jerome
The 911 GT3 R Hybrid features an electrical front axle drive with two electric motors developing 60 kW each supplementing the 480-bhp (358 kW) four-liter flat-six at the rear of the 911 GT3 R Hybrid. Instead of the usual batteries of a hybrid road car, an electrical flywheel power generator fitted in the interior next to the driver stores recaptured energy and delivers it to the electric motors.
The flywheel generator itself is an electric motor with its rotor spinning at speeds of up to 40,000 rpm, storing energy mechanically as rotation energy. The flywheel generator is charged whenever the driver applies the brakes, with the two electric motors reversing their function on the front axle and acting themselves as generators. Then, whenever necessary—i.e., when accelerating out of a bend or when overtaking—the driver is able to call up extra energy from the charged flywheel generator, the flywheel being slowed down electromagnetically in the generator mode and thus supplying up to 120 kW to the two electric motors at the front from its kinetic energy. This additional power is available to the driver after each charge process for approximately 6 - 8 seconds.
Depending on racing conditions, hybrid drive is used in this case not only for extra power, but also to save fuel. This again increases the efficiency and the performance of the 911 GT3 R Hybrid, for example by reducing the weight of the tank or making pitstops less frequent
Une petite VIDEO au Paul Ricard
Message par Corsugone » 12 févr. 2010 15:43
The Grove based team told the media on Thursday that its energy recovery system, developed throughout 2009 but disallowed as part of a FOTA agreement this year, will be unveiled in the Porsche at the Geneva Motor Show next month.
"We hope that this will be just the start of the evolution of hybrid systems developed for formula one moving across to applications where they can contribute to cleaner and more powerful vehicles," said Williams' chief operating officer Alex Burns.
Williams said the technology will also be available to buses, trains, ships and wind power generation.
Aboard the Porsche 911, however, Williams' KERS will see some racing action, with the German carmaker announcing it will contest May's Nurburgring 24 hour race.
Message par ze_shark » 13 févr. 2010 14:49
L'un n'a pas grand chose avoir avec l'autre, si ce n'est le branding hybride. Le Cayenne aura des batteries, pas une masse inertielle.La grenouille a écrit :non pas abandonné mais visiblement ils ont choisi la stratégie circuit pour lancer la "chose".
