Injection directe: dépôts de carbone ?
Message par ze_shark » 25 avr. 2009 07:03
Ces photos proviennent d'un Cayenne Turbo dernière génération (avec injection directe). L'effet détergent du carburant n'opère plus (le carburant étant injecté directement dans la chambre), il n'y a plus que de l'air qui passe par les soupapes d'admission.
Je lis que le problème est endémique sur les Audi RS4, nouveaux Cayenne et BMW 335i. Autre problème reporté, la dilution accélérée de l'huile moteur par du carburant, mais là je comprends moins pourquoi ...
Message par ze_shark » 25 avr. 2009 07:11
Une explication assez fouillée du problème:
"Gasoline engines with direct injection of the fuel into the combustion chamber, i.e., not into the intake port, suffer especially from the problem of the formation of carbon deposits on components. Carbon deposits form especially in the neck region of intake valves. A more exact analysis of how these carbon deposits form leads to the following result: Oil and fuel constituents first form a sticky coating on the components. These constituents are chiefly long-chain and branched-chain hydrocarbons, i.e., the low-volatility components of oil and fuel. Aromatic compounds adhere especially well. This sticky base coating serves as a base for the deposition of soot particles. This results in a porous surface, in which oil and fuel particles in turn become embedded. This process is a circular process, by which the coating thickness of the carbon deposits continuously increases. Especially in the area of the intake valves, the deposits originate from blowby gases and from internal and external exhaust gas recirculation, and in this process, the blowby gasses and the recirculated exhaust gas come into direct contact with the intake valve.
Especially in the area of the neck of the intake valves, excessive carbon deposits have extremely negative effects for the following reasons: In the case of Otto direct injectors, the successful ignition of the stratified charge depends to a great extent on the correct development of the internal cylinder flow, which ensures reliable transport of the injected fuel to the spark plug to guarantee reliable ignition at the spark plug. However, a coating of carbon deposits in the neck region of the intake valve may interfere so strongly with the tumble flow that ignition failures may occur there as a result. Under certain circumstances, however, ignition failures can lead to irreversible damage of a catalytic converter installed in the exhaust gas tract for purifying the exhaust gas. Furthermore, the coating of carbon deposits in the neck region of the intake valve causes flow resistance, which can lead to significant performance losses due to insufficient cylinder filling, especially in the upper load and speed range of the internal combustion engine. In addition, the carbon deposits in the neck region of the intake valve may prevent correct valve closing, which leads to compression losses and thus sporadic ignition failures. This in turn could irreversibly damage the catalytic converter. There is the potential for small particles to break away from the coating of carbon deposits in the neck region of the intake valve and get into the catalytic converter. These hot particles may then cause secondary reaction and corresponding local damage of the catalytic converter. For example, a hole may be burned in the structure of the catalytic converter.
Globular deposits are found especially on the valve stem downstream from a partition plate in the intake port. Due to the dripping of high-boiling hydrocarbons from the partition plate towards the valve neck or valve stem, globular carbon deposits eventually form there by the sequence of events explained above. These deposits on the valve stem can result in flow deficits due to undesired swirling and turbulent flow around the globular carbon deposits. This may persistently interfere with the formation of stable tumble flow from cycle to cycle.
A possible solution would be to keep these sources of deposits away, for example, from the intake valve, by completely eliminating exhaust gas recirculation and the introduction of blowby gases into the intake port. However with the combustion behavior of modern reciprocating internal combustion engines, at least external exhaust gas recirculation and the introduction of blowby gases into the intake port are absolutely necessary for reasons of emission control and fuel consumption, so that this approach is not possible."
Autre photo d'une Audi 2.0 FSI:
Message par Derrick » 25 avr. 2009 10:29
ze_shark a écrit : A possible solution would be to keep these sources of deposits away, for example, from the intake valve, by completely eliminating exhaust gas recirculation and the introduction of blowby gases into the intake port. However with the combustion behavior of modern reciprocating internal combustion engines, at least external exhaust gas recirculation and the introduction of blowby gases into the intake port are absolutely necessary for reasons of emission control and fuel consumption, so that this approach is not possible.[/i]"
Message par Corsugone » 25 avr. 2009 11:14
Raisonnement débile mais si vous avez une autre idée ?
Message par tof » 25 avr. 2009 12:25
mis a part l'augmentation de consommation d'huile, ça fait quoi de plus ? (fermeture de soupape ??)
Louis de Bonald
Message par Corsugone » 25 avr. 2009 12:47
En plus d'une perte de compression et d'une mauvaise fermeture de la soupape d'admission, cela peut tuer le catalyseur :tof a écrit :ça engendre des pannes ?
A la longue, ce n'est pas bon pour le moteur ....
De ce que j'en comprends, ces dépôts pénalisent le flot d'air à l'arrivée, cela veut dire que dans le temps le phénomène ne peut qu'augmenter.
Message par tof » 25 avr. 2009 13:13
a plus long terme ça pourrait tuer le moteur plus rapidement. le mélange n'étant plus adapté, plus ou moins détonant, la sonde lambda et le debimètre ne pouvant plus capter + compenser ce qui se passe, ça devient très difficile à contrôler.
les pistons n'ayant plus la meme valeur de détonation, certains petent plus fort que d'autres, je crains aussi pour l'équilibrage ou une casse a ce niveau.
ça fait quand même peur... le temps du bon vieux carbu....
Louis de Bonald
- sputnick
- Véhicules : Model S P90D, Z06, 850i
Message par sputnick » 25 avr. 2009 13:13
Est-ce le dépôt du carbone du CO2 contenu dans l'air l'admission, fixé sous l'effet de la chaleur des soupapes ?
Très étrange en tout cas.
- Sput
Message par Corsugone » 25 avr. 2009 14:33
Message par ze_shark » 25 avr. 2009 15:21
"Especially in the area of the intake valves, the deposits originate from blowby gases and from internal and external exhaust gas recirculation, and in this process, the blowby gasses and the recirculated exhaust gas come into direct contact with the intake valve."
Message par Corsugone » 25 avr. 2009 17:03
De plus, la recirculation des gaz d'échappement par l'admission n'est possible qu'à la condition qu'ils n'aient pas été totalement évacués lors de la phase d'évacuation, soit celle de remontée du piston. Normalement, cette phase d'évacuation des gaz est associée au phénomène de contre-pression :
Dans le cas d'un multicylindre, à l'ouverture de la soupape d'échappement, apparaît une onde de pression appelée contre-pression dans la ligne d'échappement. Elle progresse alors jusqu'au silencieux où elle se réfléchit en onde de dépression, favorisant ainsi la vidange du cylindre.
La difficulté réside dans le fait que cette onde de dépression doit arriver avant que la soupape ne se referme. Or ceci ne se produit que pour un régime donné et une configuration géométrique de la ligne d'échappement : c'est l'accord acoustique.
Cela m'amène à poser la question, est-ce que les voitures sur lesquelles le phénomène a été constaté possédées une ligne d'échappement modifiée ??
Message par ze_shark » 25 avr. 2009 18:04
Beaucoup de moteurs implémentent un circuit de recirculation des gaz d'échappement pour baisser les émissions d'oxydes d'azote. Ce n'est pas un phénomène parasite de second ordre, c'est un dispositif actif et conçu à dessin.
Sources: Wikipedia. Audi. Un autre article.
Ces systèmes sont également apparus sur les motos il y a une dizaine d'année, il me semble.
Message par Corsugone » 25 avr. 2009 19:12
Message par vravolta » 26 avr. 2009 07:42
Par ailleurs, bien avant la recirculation, la loi oblige à réinjecter les valeurs d'huile issues du bas moteur dans l'admission. Et donc même quand la recirculation n'existait pas, les collecteurs d'admission étaient tout huileux à l'intérieur à cause de ca. Donc la recirculation doit pas aider, c'est sur, voire même ca doit faciliter le fait de rendre cette huile solide, mais la provenance n'a rien d'anormal en fait, c'est surtout sa non évacuation qui pose problème en fait.
- David
Message par David » 26 avr. 2009 08:03
Les M5 E39 souffrant du même mal, c'est ce qui semble être conseillé ainsi que de pousser régulièrement le moteur dans les hauts régimes pour "décrasser" le moteur !
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 105 invités
